Diagnostic & Calibration Stuff
Old Jun 2, 2023 | 09:54 PM
Tech_JLR's Avatar
Originally Posted by piper 888
Hello Tech JLR, I have a 1995 X-300 that has no OBD II port. like my newer XK8. How did they diagnose these cars when needed? It there another port that I don't know about not located under the left lower dash?
IF YOU DONT HAVE AN OBD2 PORT ON THE DRIVER SIDE, THAN I THINK YOURE VEHICLE IS A 1994.5, I BELIEVE THERE SHOULD BE A SERIAL PORT IN THE TRUNK THAT YOU CAN USE, BUT Its ONLY FOR POWERTRAIN MODULEs NOT MUCH YOU CAN DO,,, IF YOU HAVE A VCM1 THAN YOU CAN USE AN ADAPTER, OR MAKE YOUR OWN ADAPTER IF YOU HAVE THE PINOUT FOR THE SERIAL PORT IN THE TRUNK TO AN OBD2 CONNECTION.
If it's a 1995-up I think it should have and obd2 port, but I could be wrong on that
Old Jun 2, 2023 | 09:57 PM
Tech_JLR's Avatar
Originally Posted by Vee
You have an XK8 without an OBD2 port?
XK8 all have OBD2 PORTS.
XJ year 1994 have the serial port in the trunk
Old Jun 2, 2023 | 10:02 PM
Tech_JLR's Avatar
with the VID block cars you get kneecapped and forced to SDD on almost all of them except the earliest x202s.[/QUOTE]
Yes Sir, I understand what you mean, we program used modules for other shops, we go thru this alot
Old Jun 2, 2023 | 10:14 PM
Tech_JLR's Avatar
To piper 888
check this link here on this forum:
https://www.jaguarforums.com/forum/x...ag-xjs-251086/
Old Jun 2, 2023 | 10:29 PM
xalty's Avatar
all x300s have a j1962/obd2 port
they probably pushed it out of its holder
Old Jun 3, 2023 | 06:08 AM
piper 888's Avatar
No my XK8 has a OBD II port, my 1995 Jaguar X-300 does not and that is the problem.
Old Jun 3, 2023 | 07:25 AM
motorcarman's Avatar
I have NOT seen a North American X300 without an OBDII connector next to the gearbox tunnel.
Maybe it is a ROW car?
Old Jun 4, 2023 | 06:31 AM
  #28
piper 888's Avatar
Hello Motorcarman, what is a ROW and I have had the center consol out to replace the safety neutral switch and never saw a OBDII connector. I always thought it would be on the lower left front dash by the door hinge post on a left hand drive vehicle.
Old Jun 4, 2023 | 07:19 AM
ROW = Rest Of World (as opposed to North America)
Old Jun 4, 2023 | 02:25 PM
  #30
Tech_JLR's Avatar
If it's 1994 XJ and you don't have the OBD2 on the driver side under-dash.... than diagnose the engine codes from the dash either center display or cluster, when you first turn ignition on without starting the engine, it will display a number example ( 1 or 2 or 4 etc..), to erase the codes just start the engine and it will erase all engine codes and log new codes if there is any, and these new logged codes will be read at the next ignition cycle without starting the engine...
ABS and TRANS error codes on a non-obd2 XJ will be read thru the serial port in the trunk
Il_Boros
Mar 31, 2026 09:39 PM
harryf
General Tech Help
43
Mar 31, 2026 07:10 PM
Jaronstoys
Apr 1, 2016 02:00 PM
bigreguk
Oct 15, 2013 02:43 PM
maxwdg
Aug 4, 2012 11:16 AM
