Digital Clock Issue
Old Jul 25, 2012 | 09:12 AM
jeronimojaxon's Avatar
Default Digital Clock Issue
The digital clock above the stereo does not display properly. The numbers are faded to various degrees; the only part that seems unchanged is the colon between the hour and the minutes. Is it repairable, or does it need to be replaced?
It's not a major problem, it's just one of those things that bug me.
Old Jul 25, 2012 | 11:17 AM
mgb4tim's Avatar
Try a search. Plenty if info about it.
Old Jul 25, 2012 | 12:31 PM
Doug's Avatar
Send it to Module Masters.
Old Jul 25, 2012 | 10:10 PM
aholbro1's Avatar
ModuleMaster | Services | Clock Modules
Like Doug said...
Old Mar 18, 2016 | 06:05 AM
Alan Stoldt's Avatar
Question
Resurrecting this old post to ask a tag-along question.
I plan on sending my unit to MM as stated above.
The clock is totally out, and when I bought the car, the connector was unhooked.
I pluged it back in and seat heater switches were operative.
Drove up town and went to lock it. Walked away, got about 10 paces from teh car and the alarm started going off. *Very loud BTW* Put the ky in and alarm shut off fine. My trip to the store postponed, I went home and unhooked it, not a problem since.
Is this common with the other noticed symptoms that the alarm is tripped and will the repair fix all? I'd hate to have the rebuild done and still not be able to use it.
Thanks.
Old Mar 18, 2016 | 07:45 AM
aholbro1's Avatar
Never heard of it. When I sent mine away to Module Masters, I used a borrowed unit for awhile, to fill the hole. Never had problem with either one. Are you certain you didn't inadvertently set off the alarm with the key FOB? Maybe something in your pocket made an unintended long-press?
I'd try it again to make sure the events are related rather than a random coincidence. If so, sounds like a wiring problem somewhere that you'll need to search out.
Old Mar 18, 2016 | 06:54 PM
No key Fob, just the mechanical Key. This was after a week of owner it, so pretty sure I didn't do anything different other than hooking the module back up again. I will test before sending, just to see. Thanks.
A British friend suggested that perhaps the door unlock switch was sticky....
philwarner
Oct 4, 2024 01:37 PM
99xk8guy
May 28, 2024 09:36 PM
Jefro
Sep 15, 2015 01:44 PM
1964Daimler
Sep 9, 2015 11:28 AM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
