Digital mileometer display - two figures dimmed
Old Oct 2, 2016 | 09:32 AM
biffta's Avatar
Default Digital mileometer display - two figures dimmed
Recently I've noticed that the two left digits of my digital mileometer display are not as bright and clear as the ones to the right. Is this display illuminated by a bulb or bulbs, if so I can't see why it's partly dimmed and not just failed as would happen if it was a bulb or is the whole display digital meaning that two digits are failing?
Thanks.
Old Oct 2, 2016 | 10:37 AM
Jagboi64's Avatar
There are bulbs behind the odometer, I think you need to remove the instrument cluster to get to them.
Old Oct 2, 2016 | 10:45 AM
biffta's Avatar
Thanks for that. At least now I know. Not looking forward to the prospect of removing the cluster though. The dimming digits aren't that bad!
Thanks again.
Old Oct 2, 2016 | 09:51 PM
Jagboi64's Avatar
It's not hard to do, 4 screws from underneath and then it comes out. Have the steering wheel as low as it will go, and as far out as it goes. Actually seeing the screws can be the hard part, they are deeply recessed. Lie in the footwell and look up and you'll see them, on the front edge of the cluster. A flashlight helps too.
Old Oct 3, 2016 | 03:13 AM
biffta's Avatar
Thanks for that, as a matter of interest are the bulbs clear or if not, do you know what colour they are?
Thanks again.
Old Oct 3, 2016 | 12:44 PM
Jagboi64's Avatar
The bulbs are a bluish green. I believe the part number is LNA5180CA, but I'm not 100% sure. There are 2 sizes of base and I don't know if that's the right one.
Old Oct 4, 2016 | 02:30 AM
SleekJag12's Avatar
Biffta, did you give the cluster a good couple of whacks with your knuckles? Sometimes a little coercion will "repair" a loose bulb connection. Possibly save you a removal job.
I thought the bulbs were the common clear push-in type. But i could be wrong. Foggy memory from last time I saw the cluster out of the car.
Old Oct 4, 2016 | 03:20 AM
biffta's Avatar
No I didn't. It's normally my first action with any problem. Will try it!
Thanks.
Old Oct 4, 2016 | 03:22 AM
biffta's Avatar
BTW, the screws you are referring to are they below the "ledge" which protrudes from the instrument panel and in which the switches are fitted?
Also, found this link to removal and unless I'm mistaken, the removal process seems to be different! Bit confused now.
http://tinyurl.com/hk3blkv
Old Oct 4, 2016 | 04:37 AM
countyjag's Avatar
Bifta,
The removal process shown on the link is correct. You have to remove the trim panel in the drivers footwell, then there are four screws, then as the binnacle is coming out, you need to unplug the two electrical connectors. Having had the pleasure more than once, it is definitely not a big job.
The link then goes on to explain how to open the instrument pack, which may be where the confusion arises, but that too is not a complicated task, and is fairly obvious when you have the pack in front of you.
Contrary to what was said earlier, from memory the instrument pack bulbs are clear rather than blue/ green, but again, this will be obvious when you have it apart.
Old Oct 4, 2016 | 05:46 AM
biffta's Avatar
Originally Posted by countyjag
Bifta,
Thanks so much. Really appreciated.
Old Oct 4, 2016 | 11:50 AM
Jagboi64's Avatar
Yes. I was assuming the trim panels were removed, sorry for not making that clear. I did it yesterday at the junkyard on a 94 XJ40 and the trim comes off first. That's just a few screws.
And yes, once the instrument cluster is removed it has to be taken apart, but again that's just a few screws.
Old Oct 5, 2016 | 02:33 AM
biffta's Avatar
Thanks for that, appreciated.
Dale Dunn
Dec 8, 2023 12:07 PM
NTL1991
Oct 2, 2016 02:14 PM
powerhouse
Sep 29, 2016 11:55 AM
Johnken
Sep 29, 2016 09:12 AM
Johnken
Sep 25, 2016 01:58 PM
