drive shaft question
Old May 5, 2010 | 09:27 AM
shl1980's Avatar
Default drive shaft question
Hi all,
I'm a bit confused about the following (the car is Daimler V12 from 1995):
In the manuals there is warning which reads:
To preserve 'drive line' refinement. individual parts. other than
fixings. MUST NOT be renewed. In the event of any balance or
drive shaft component related problem. the complete assembly
must be renewed.Under no circumstances must the flexible
coupling (or its fixings) be loosened or removed from the drive
shaft flange.
On the other hand it is possible to buy Propshaft flexible coupling
Part No: CBC8996*
So what is the reason, that I shouldn't loosen or remove it? Balancing? it there a way to "re-balance it"?
Any experience with replacing it?
thanks.
Old May 5, 2010 | 12:20 PM
Doug's Avatar
I've wondered the same thing. I've never done the job on a X300 but I've read where others have.
I think the key is to make sure everything goes back together exactly the same way as it was disassembled...to keep everything in phase. And there is a definite "this side forward" on the coupling itself.
Others will chime in.
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
dcvickers
Sep 2, 2015 06:14 PM
XFR_Gold
Sep 2, 2015 12:24 PM
