Electrical problem
Old Jul 27, 2022 | 03:13 PM
X300lover69's Avatar
Default Electrical problem
Hello! Just had my jaguar (x300 95 3.2 EU version) repainted and after it came back from shop bunch of electronics had stoped working, including;
  • trunk does not open with button on it, but work with button from dashboard.
  • blinkers are working but super fast
  • dash board show 0 mpg current and fuel 0, but shows range correctly
  • screen washer fluid sprayer
I hoped that while stripping or putting back together the car there might be some connection or plug not put in proper place which might cause these problems.
Any advice on how to approach this problem would be appreciated.
Old Aug 13, 2022 | 02:02 AM
Parker 7's Avatar
under the car on all 4 corners there is a black square 13 wire connector that gets corroded , this effects the direction blinkers
your washer pump wires go through the right front under connector
the trunk release outside button wires pass through a cover on the cars right trunk curved hinge arm that has a history of rubbing under the cover
n17gary
Dec 6, 2023 05:26 PM
car5car
Feb 25, 2019 04:34 PM
Paulofvfreitas
Feb 16, 2019 01:23 PM
tonyodo
Nov 5, 2018 04:03 PM
mehsfx
May 12, 2008 06:20 PM
