Engine misfire - No warning lights or rational
Old Aug 5, 2011 | 08:46 AM
Canadian_XJ6's Avatar
Default Engine misfire - No warning lights or rational
Good morning one and all,
I purchased my 96 XJ6 VDP just over a year ago and so far haven't had any problems that I couldn't fix (radio, power mast, lights). However my jag has started with a misfire while driving it. I notice it a lot while the car is cold, it will misfire but not in a specific time, just sitting at the stop light and I may get 1 miss or 5misses. Also once my car warms up the misfiring disappears, it just stops doing it until I let the car go cold then on start up it does it again.
Whenever the engine has its misses, the RPMs dip from idle (around 800RPMs) to 650RPMs but just for a split second.
Also one day when it was VERY hot I had the AC on and was in stop and go traffic and I noticed that when I put my foot down on the gas to move, the engine would almost choke out. I had to feather the throttle from a stop to keep the car from stalling but again, that only happened the once and it went away when I turned the AC off.
I'm going to try to start with just the basic testing, maybe just some bad plugs. I did have them changed 8000km ago so I'd be surprised if they had died that quickly. I've got a funny feeling that I've got the iridium plugs in, but I won't know for certain until I get them out.
Does anyone have an idea what would be causing this misfire only during the first 10min of driving? Or the strangle hold on my engine by the ac in stop and go traffic?
Cheers,
Mike
Old Aug 5, 2011 | 05:04 PM
sparkenzap's Avatar
Any codes? The ckps is always a concern on any misfire and it has many intermittent failure modes reported. A scope would let you see the signal.
Old Aug 6, 2011 | 11:26 AM
bgy08's Avatar
It could be an ignition coil starting to go.
Old Aug 8, 2011 | 09:53 AM
Unfortunately I do not own a scanner, grad school loans prevent me from owning much, is there a place I can take it to get scanned?
Also forgive me but what is a ckps?
I had a fear it was a coil going, blasted things are expensive here, 180$ from Canadian Tire/Part Source.
Old Aug 26, 2011 | 08:48 PM
mtotrainer's Avatar
Default hellow fellow countryman
where abouts are you located? I live in oshawa ontario perhaps we can help each other in our car wows and repairs. I also have a 96 vanden plas....Jamie
X_Type_South_Africa
Dec 9, 2015 05:37 PM
tberry6686
Sep 20, 2015 03:22 PM
Thempsc
Sep 7, 2015 02:29 AM
Oliver9218
Sep 3, 2015 05:33 PM
Aranon
Sep 1, 2015 01:00 PM
