engine revs on its own
Old May 28, 2008 | 08:25 PM
mtotrainer's Avatar
Default engine revs on its own
I have a 1996 XJ6 VDP with a 4.0 six and it seems to not want to coast when I lift my foot off the accelerator pedal.If I shift it into neutral at speed the engine will rev to 3000 rpms quickly.Any ideas what could cause this? Thx Jamie
Old May 28, 2008 | 08:30 PM
jag_genius's Avatar
Default RE: engine revs on its own
sounds like you need a throttle body.
Old May 28, 2008 | 08:42 PM
ibjags's Avatar
or engine setup
including throttle potentiometer recalibrate
make sure throttle body is clean as well
and low battery voltage can cause throttle pot to go out of range also
so check battery condition too using a good battery tester
cissdm
May 3, 2016 06:02 AM
Thang Nguyen
Oct 12, 2015 01:25 AM
OkieTim
Sep 8, 2015 04:48 PM
AL NZ
Sep 4, 2015 08:39 PM
XFR_Gold
Sep 2, 2015 12:24 PM
