engine revs too high at start
Old 07-26-2007, 10:18 AM
bigdreams05's Avatar
Default RE: engine revs too high at start
Oh boy....check the gas pedal, the intake manifold, the line from the pedal to the intake.
Old 07-26-2007, 11:39 AM
ken@britishparts.com's Avatar
Are you saying the pedal physically moves?
Old 07-26-2007, 01:41 PM
Well, the pedal SHOULD NOT move, and I said to check the pedal, because if it's pressed down, then obviously this would happen! As for vacuum leaks, usually it would cause for the car to not accelerate, not to over-accelerate! If the pedal moves, maybe it's a transformer car! HAHAHA!
Old 07-26-2007, 03:21 PM
Also, check the throttle body linkage. Sounds to my like somethings in a bind and caught wide open. I don't think an electrical problem would give you this.
Old 07-26-2007, 06:25 PM
either throttlle set to high ... or bad throttle body ,usual.
toronadomike
08-07-2022 03:41 PM
jehart49
09-12-2015 05:36 PM
tberg
09-07-2015 07:32 AM
1964Daimler
09-02-2015 11:41 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: engine revs too high at start
