Engine stalls? CPS?
Old May 8, 2018 | 03:42 PM
RB_jaguar's Avatar
Newest update follows.
Ordered a set of 6 used but original coils. Will replace all six. Also ordered a set of new spark plugs champion rc12yc.
Here's my question - the gap of the new plugs is 0.75mm or about 0.03 inch. I read somewhere that the gap should be round 0.9mm. But the smaller the gap the easier is for the coil or am I wrong.
What do you think guys, should I make the gap bigger to 0.9mm or leave it 0.75mm? Whats the best for this car.
Thanks.
Old May 8, 2018 | 03:55 PM
Lady Penelope's Avatar
http://www.jagrepair.com/images/TSB/...6%20Engine.pdf
As the coil over years gets weaker bring the gap smaller , but the coil is on it's way out . higher current across the gap .
To make a new coil last longer bring the gap larger to the 0.9 mm , but no larger . lower current across the gap .
Destructive heat is a function of higher current
Old May 8, 2018 | 05:05 PM
Vee's Avatar
Vee
Spark Plug spec for the AJ16 engine is .035"...or 0.9mm
Old May 8, 2018 | 06:12 PM
Don B's Avatar
An interesting note is that for engines that suffered rough idle, hesitation or other drivability concerns, Jaguar issued a TSB indicating the spark plug gap should be set larger, at 0.038 inch / 0.96mm. This TSB also confirms that the revised spark plug specification, Jaguar part EBC 8143, is Champion RC12YCC:
05.1-36 Rough Idle/Drivability - Diagnosis to Follow Prior to Replacing MAF
But Parker's advice seems like a good idea if your coil is failing.
Cheers,
Don
Old May 13, 2018 | 07:53 AM
al_roethlisberger's Avatar
Originally Posted by Scotlad
I am using QYL brand coils on my xj6. Amazon has them for $79.00 for a six pack! I have had them for about 10 months and so far no problems. They also came with the paper gaskets for each coil.
I guess it is possible that over time we'll find some inexpensive aftermarket coils that are as good, or nearly as good, as the Japanese OEM coils.
Perhaps these QYL units are? I have no idea, but please keep us updated over time how these work out for you.
Old May 13, 2018 | 11:27 AM
Scotlad's Avatar
When I bought these QYL coils I was pleasantly surprised at the quality of construction. They were actually a little heavier than the original Japanese coils. I had not actually tried any other generic coils but when I was looking at close up pictures on Amazon of other brands of coils I noticed that some of them had sub par molding, rough edges and such which to me at least, can be a sign of lack of quality control and if that is on the outside that the consumer can see, what is on the inside?
The fact that an electronic component in made in China does not necessarily mean that it is inferior. Most of our consumer electronics are made in China, it is all about quality control.
I remember when the original Japanese coils used to sell for $300-$400 each. $2400 for a six pack of coils! The markup on these coils was insane. An ignition coil is a fairly basic device, nothing high tech and should be priced as such.
Old May 13, 2018 | 01:01 PM
Thanks, I may be buying a set for some testing. I'm suffering from what I think is a heat-soak related issue that causes intermittent stalls at idle or low RPM. I'm checking out the crank position sensor next because I already have a new one on-hand. But if that isn't it, perhaps one of my coils is dying. For $60 for a set of 6, these coils would be a cheap and quick test since it is so hard to find which coil could be failing.
Old Jul 11, 2018 | 02:14 AM
  #28
JohnXJR6's Avatar
Hi Gents, I am having similar problems. Crank sensor is only a few years old, coils replaced about ten years ago, could they be worn out? It has been a weekend car for the last seven years, so not that many hours on then. I would suggest, as I think previously mentioned, cleaning the under hood earth points and using contact cleaner, not wd40 or similar, to clean the connections on the ecu and any relevant connections. This previously solved some running issues for me.,
Old Jul 11, 2018 | 11:24 AM
If your symptoms are the same as the first post there are some free things you can try before component change .
The main engine block ground from the lower starter bolt to the frame . Best to get from under the car with a 13 mm on the starter bolt and a 10 mm on the car frame .
Injector cleaner in the tank ( X brand recommended by many ) . The injector pulse width is at it's shortest and most critical at idle . Storage time may have gummed up the injecors
Old fuel ?
Do you have the start but stalling after a couple of seconds as the fuel rail is drained of it's initial prime charge or pressure amount . A not completely failed CKPS related issue .
Old Jul 11, 2018 | 07:31 PM
  #30
trampintransit's Avatar
What's the code for the QYL coils please..is it still a LHE1510AB ? ..I'll see if I can find them in the UK?..and what brand were the cheap ones that failed?
Old Jul 11, 2018 | 08:39 PM
  #31
Scotlad's Avatar
trampintransit, I bought my QYL coils from Amazon over a year ago and mine are still working great.
juha_teuvonnen
Dec 1, 2014 03:07 PM
Jetze Mellema
Aug 6, 2013 10:13 PM
db500
Jun 28, 2012 06:22 AM
mrtalkradio
XJ40 ( XJ81 )
25
Dec 11, 2011 03:51 AM
mrtalkradio
Sep 18, 2011 03:06 PM
