Error P1621
Old Oct 18, 2009 | 04:35 AM
x300's Avatar
Default Error P1621
I have a problem with the P1621 error and not delete it until the engine is working perfectly when removed shall cease to read the oxygen sensors, this is disconnect the battery until 15 minutes. And all be well at times one day, sometimes a week and sometimes two hours. Yes Decide as it gets when the engine will not start at first key is turning, because the starter will not start. And as soon as the engine will not start at first turn the key is taking an error P1621.
Old Oct 23, 2009 | 06:27 PM
bhmaxjag's Avatar
what jag do you have? Maybe you posted in the wrong forum? a p1621 code is not a code found on the x300 vehicles
Old Oct 23, 2009 | 06:33 PM
bhmaxjag's Avatar
Update...not listed in my list of fault codes but actually is a fault code, though more common to GM vehicles. Likely a bad ECM/PCM
Old Oct 24, 2009 | 01:39 AM
x300's Avatar
x300, 3,2 sovereign
Old Jan 1, 2010 | 08:28 PM
crystalvision's Avatar
Default Update
Hi
Did you manage to get that sorted, I too have a P1621 error code and stalling behavior
ricwel
Jun 23, 2023 05:14 PM
magmedia
Aug 15, 2019 08:54 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Poet
Oct 2, 2015 09:00 AM
Collector1
Sep 28, 2015 03:52 AM
