Evaporative loss flange, is the black fitting a point of failure?
Old Mar 25, 2018 | 10:35 PM
al_roethlisberger's Avatar
Question Evaporative loss flange, is the black fitting a point of failure?
Referencing part 11 in the diagram below, which is the "evaporative loss flange". The flange has two parts, the white plastic pass through electrical plug for the fuel pumps, and the black plastic "valve?" to which the evaporative metal vent tubing attaches.
I'm curious about the black plastic fitting (valve?) and whether it needs to be checked and if so how and what would be normal operation?
I have the cap/flange off in preparation for my fuel pump replacement, so I just want to make sure I can check the fitting (valve?) proper operation before buttoning it all back up.
Attached Thumbnails Evaporative loss flange, is the black fitting a point of failure?-td6327.png
Old Mar 25, 2018 | 11:33 PM
Lady Penelope's Avatar
Dude , put a 9 volt battery on it and hear if it clicks , if not a 9 volt battery try a 12 volt battery source . I don't see a electrical connector so you may have to blow in it to hear it click ?
Thanks , Parker , Flight Line Avionics Specialist ( Retired ) / Trans World Airlines
Gotta go to bed now as my Mother say's so
Old Mar 26, 2018 | 07:21 AM
No electrical connection, and I had planned to blow on it, but just wanted to verify how it is supposed to work. Otherwise I won't be able to know if its behavior following my blowing on it is normal or not.
I'm just curious what it really is and does, and how.
The black "valve" part isn't available as a separate part, just the entire evaporative cap. Again I don't necessarily think it is malfunctioning, but wanted to check it before I put the back deck and tank all back together.
robertjag
Jan 21, 2014 12:17 PM
randyb
Jun 7, 2012 12:15 PM
jhenryr
Nov 10, 2010 09:46 PM
Thom2
Apr 8, 2009 07:11 AM
the almiesta
XJ40 ( XJ81 )
May 9, 2008 04:00 PM
