Exhaust leak
Old Oct 12, 2010 | 07:19 PM
tbone's Avatar
Default Exhaust leak
I have a 95 XJR . I took my CAT to a exhaust shop told him I need a new exhaust , after being floored by the cost of that , he notices a exhaust leak at the Manifolds . He said he could weld it . I told him no way Ill replace before I weld IRON . I ordered 2 manifolds and gaskets . I took the heat shield off and both are cracked in the center WTF !! Do the supercharged motors run that hot ?? is this normal to have happen ?? My thought was a sudden thermal change like a puddle of water ? Or maybe the guy that owned this before me ran the **** out of it !! Any thoughts ?
Thanks in advance
Old Oct 12, 2010 | 08:38 PM
Doug's Avatar
It's pretty common on X300s and more so on the XJRs. I think the castings are just too thin.
Both of mine cracked. I was lucky enough to find two good used ones for $100 each.
Old Oct 12, 2010 | 09:37 PM
tbone's Avatar
Wow , that's cheap . The ones I bought were more but also the manifold closest to the fire wall has an opening where the one I have doesn't . I'm wondering if I can effectively cap that . I'm guessing its an emission something or other.
Thanks for the info
Old Oct 12, 2010 | 11:00 PM
Doug's Avatar
Thanks for the info
It's for an EGR pipe....which not all of the cars have. I threaded the hole and used a pipe plug. If you don't have the stuff to do it any machine shop can do it for you in just a few minutes if you catch 'em at the right time.
Old Oct 13, 2010 | 08:49 PM
tbone's Avatar
Doug , thanks again I will do that . Gotta get the Cat back on the road , now I need to decide on the exhaust . UGH !!
Old Oct 13, 2010 | 09:14 PM
bhmaxjag's Avatar
The cracking is a common issue. I had good luck cleaning my manifolds up and repairing the cracks with a product called Thermosteel. It hardens as it gets hotter..worked wonders! I no longer own a cat, but just figured I'd chime in.
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
rachelstr
Sep 3, 2015 12:59 PM
