Exhaust Part?
Old Nov 7, 2022 | 09:09 AM
cdma's Avatar
Default Exhaust Part?
While replacing my manifolds, I seemed to have stripped the hoses that go into the manifolds. Does anyone know what these are, what they are used for, and what the part is called so I can search for another one?
Old Nov 7, 2022 | 11:18 AM
Parker 7's Avatar
Secondary air injection ( smog pump )
Genuine Air Injection Pipes-3.2/4.0 Litre (3.2 Litre,4.0 Litre,4.0 Litre (california)) For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
Old Nov 7, 2022 | 11:52 AM
cdma's Avatar
I guess I will have to find one on a salvaged car since the only place I have seen them is in the UK. What is interesting is that I put them in as far as I could, put a little gasket material around them, and had no errors. Must not be a whole lot of pressure
Old Nov 7, 2022 | 11:57 AM
Cafcpete's Avatar
It’s only used at startup. It helps keep the emissions down whilst the car is warming up.
You won’t (to at least I didn’t) get an error even if you in plug the pump.
Old Nov 7, 2022 | 12:18 PM
Parker 7's Avatar
The secondary air injection ( smog ) pump only runs for 60 seconds off the top of my head
There may be an issue if you have to do an exhaust emission test based on your location
But this depends on what point in time they take the readings
A leak in the line fittings is a different story on effecting or biasing the O2 sensors to get the proper fuel trim and unburnt hydrocarbons which is an emissions test look at
So if the smog pump is running you would be injecting fresh unconsumed O2 just upstream of the O2 sensors , but the O2 sensors are not used until the engine coolant temp semsor sees 88 C ( closed loop )
So in effect the smog pump is diluting the exhaust just enough to cheat the emissions test and get passed
We have the 2 things working against each other so there is a balance or sequence that must be meet
Old Nov 7, 2022 | 01:16 PM
cdma's Avatar
On a side note, I replaced all my O2 sensors, and there seems to be a little "more pep in her step" and not sure if that is it or just changing out the manifolds with ceramic-coated ones.
Old Nov 20, 2022 | 07:46 PM
cdma's Avatar
Still looking for this part if anyone is parting out a car. Pretty pissed at myself for not taking it off my parts car before sending it to the crusher. Next time I will know. The only one I have found online is across the pond on eBay. Not yet ready to pay the shipping on this.
Old Nov 20, 2022 | 10:40 PM
Nobeel Masri's Avatar
I am in the middle of taking parts from a donor car and wasn't going to be taking the hoses.
Can you confirm you need just Parts 5 & 6 in the link?
They're yours if you pay for shipping. Drop me a message.
Tom Connolly
UK & Eire
Apr 29, 2022 04:57 PM
Beginner
E type ( XK-E )
Jan 26, 2022 10:43 AM
Jaguar1611
Dec 10, 2021 02:39 PM
SteveJames
Dec 26, 2017 01:04 PM
98intrigue
Aug 5, 2016 03:29 PM
