Forum Suggestion
Old Dec 31, 2021 | 06:28 AM
cdma's Avatar
Default Forum Suggestion
Maybe this is out there but I am not sure where.........Over the last two weeks, I have been working on a few issues on my X300. After speaking with many of you, I have learned to ask the right question to get to the correct answer with my many problems. I know that if you know what to search for on this forum and learn how to read the manual, you will come close to finding the correct answer.....or at least close. After all, this car has been out there for a while, and I am sure we have run into just about every issue that this car can have. Manipulating the search function to search for the right things, I found solutions to some of my problems back when this forum was created only after figuring out the solution. It would be cool if we had a sticky or something similar that once we found the solution for a particular situation, we could post it or change the subject that would be easy to find. Maybe even create an off-forum solution manual. I have no clue what this would look like, but there are people smarter than me out there that might have a solution. Just a suggestion.
Old Jan 1, 2022 | 10:11 AM
bjarnetv's Avatar
I find its a lot simpler to just search the site using google, as that shows all the unrelated threads that veer into the subject you are searching for.
toaster
Apr 23, 2018 08:48 AM
b1mcp
May 14, 2014 07:36 PM
danielsand
Oct 26, 2012 08:40 AM
dennisw
Oct 14, 2011 08:09 AM
DaleD
Feb 18, 2010 02:06 AM
