Front brake hose fitment
Old Sep 3, 2024 | 03:46 PM
rich201060's Avatar
Default Front brake hose fitment
Hi ,
Im rebuilding my X300 front subframe , I have re-furbed callipers and new original hoses. When i screw the hose into the calliper it bottoms out, is it meant to seal inside or
should it have a copper washer like the rear , if so it will need shortening.
Thanks for any advice,
Rich
Old Sep 3, 2024 | 08:02 PM
Parker 7's Avatar
May need the file off the end of the caliper fitting so the hose fitting snuggles down ( no loose filings to cut caliper piston O - rings )
I had a car once that the O - rings were cut by chrome flaking off a " remanufactured " wheel cylinder and the shuttle valve didn't come over , what a ride down a long city traffic hill but made it
Researching ( albeit on paper )
Search Genuine Brake Disc And Calipers Parts For Jaguar Xj 1995 - 1997 (from 720125 To 812255) (x300) Classic | Jaguar Land Rover Classic Parts
Old Sep 4, 2024 | 03:05 AM
rich201060's Avatar
Thanks for the advice , I think the after market parts aren't always correct.
Rich
Old Sep 4, 2024 | 07:46 AM
Parker 7's Avatar
If it is a AN fitting , the bevel in the pic is what seals , so you can't remove the bevel
Do you have a pic of your situation ?
I do recall seeing O - rings on the bevel in situations but can't say for this as I have not removed mine
Old Sep 4, 2024 | 03:26 PM
rich201060's Avatar
It doesn't have a bevel just a plane diameter I believe now to assist thread engagement, I have found some copper washers however in amongst some spares. Im confident shortening the fitting will work with a copper washer as the mating faces are very well machined plus a little hydraulic sealant will help.
Thanks for your help
Rich
mickvic
Aug 23, 2024 02:31 AM
Joexkr2001
Feb 20, 2023 07:50 PM
dvjag
Apr 12, 2020 08:52 PM
plums
Aug 21, 2013 04:22 AM
