Fuel cut off switch question
Old Apr 14, 2023 | 10:54 AM
Anbran's Avatar
Default Fuel cut off switch question
Does the fuel system AND ignition cutout as well?
Old Apr 14, 2023 | 12:12 PM
Parker 7's Avatar
The fuel injectors have power :: sitting :: on them with the closing of the large ECU control relay
The ECU provides the timed ground for each injector for proper fuel injection
This large relay is controlled by the ECU and brings power back into ( sepeate juntion splice ) the ECU to funtion as the 2nd power
The 1st power source is the right engine bay fuse box relay
ECU needs both power sources at all times
Old Apr 14, 2023 | 12:15 PM
Parker 7's Avatar
Have you reset the inertia / crash switch ?
Is your starter sag voltage staying up and not taking a dive
Old Apr 14, 2023 | 12:29 PM
Vee's Avatar
Vee
If yo mean the inertia switch, then only the fuel pump is disabled. The car will want to start, but never turn over, since it gets no fuel....until you run out of battery.
Old Apr 14, 2023 | 05:01 PM
Anbran's Avatar
I jumped the inertia switch and attempted to start the car. This time, no starter either. I reset the switch and connected the connector to the switch. Starter worked....but no start. ,
So, with respect to the relay in the trunk....I put a universal relay there instead. No start.
I'm confused with regards to a second relay under the hood in the engine compartment you mention?!
Sag time?
Old Apr 14, 2023 | 07:04 PM
Parker 7's Avatar
Large right # 5 relay for the injector power
right engine bay fuse box relay # 9 for the 1st power to the ECU
Input from others have helped me think more of other items to check for starter sag
Laptop computer recharge brick going out as well as spare
Old Apr 15, 2023 | 02:08 PM
motorcarman's Avatar
Check the fuel pressure!
Old Apr 15, 2023 | 06:46 PM
Parker 7's Avatar
The fuel pump relay will click in your finger 3 times in engine starting sequence
On for 3 seconds then off then back on when CKPS sees engine rotation
The fuel pressure should be trapped in the fuel lines between relay closing
You can slightly remove a fuel line nut to see if you have some dripping pressure as a crude knowledge
Use 2 wrenches least twisting the tubing
Fuel pressure is 43 PSI
Sometimes there is a small leak of the trapped fuel pressure like overnight and requires a couple of rotations of the key to the run position to get the pressure up , this gives you more then 1 count 3 second fuel line charging ( different then cylender priming term )
Old Apr 16, 2023 | 01:07 AM
Parker 7's Avatar
Have you put your cylinders in a bore wash condition?
Do you get a couple of combustions like 1 , 5 , 10 count ?
Hktk
Sep 9, 2021 07:57 PM
ahunt4
Jan 20, 2015 10:32 PM
pdowning6
Dec 12, 2010 03:16 PM
last2letUdwn
Aug 11, 2008 09:27 PM
XJ40 ( XJ81 )
Jan 15, 2007 08:54 AM
