fuel/gas gauge
Old Jun 28, 2015 | 04:31 PM
19jag95's Avatar
Default fuel/gas gauge
Sometimes my gas gauge works but most of the time it does not. How would I find the problem. How should I proceed. I know it may be a bad ground but but how would I find it.
Old Jun 29, 2015 | 12:06 PM
SD96XJ6L's Avatar
You need one of these buddy:
https://www.fcpeuro.com/products/jag...-xjr-dbc012042
Quick fix just make sure the tank is near empty before you remove it from the back of your tank (accessed thru trunk)
This will take 5 minutes to replace just remember where to relocated each connector.
Old Jun 30, 2015 | 08:43 AM
19jag95's Avatar
Thanks, I will have to get one.
Old Jul 19, 2015 | 11:25 PM
19jag95's Avatar
Did exactly as you suggested and all went perfectly. Done in 5 minutes as you said. So simple that I thought for sure I left something out, but nope. Thank you
X308XJR
May 20, 2019 06:50 PM
workworkwork
Oct 23, 2015 10:26 AM
vwbusbits
Oct 13, 2015 03:43 AM
3lvis
Oct 1, 2015 01:56 PM
