Fuel Gauge Issue
Old Jul 18, 2015 | 06:22 AM
97XJR-Flausa's Avatar
Default Fuel Gauge Issue
97 XJR. Having issues with my fuel gauge. It is pegged at full until almost empty then goes from full to empty in the span of like 50 miles. Replaced the fuel sender unit in the tank already. Could it be a grounding issue? If yes, where should I be looking? Wanted to get any opinions before I replaced the sender unit for a second time. Thanks
Old Jul 19, 2015 | 06:59 AM
EZDriver's Avatar
If you look in the stickies somewhere there is a diagram of all the grounded points. I don't know if you live in an area where there is a lot of moisture or not. If so you might look at all the grounded points and clean them with a good contact cleaner.
Old Jul 19, 2015 | 09:12 PM
motorcarman's Avatar
Y'all do realize that Jaguar addressed this fault about 20 years ago????
TSB 05.1-13 has a diagnostic fault finding guide. I uploaded it YEARS ago to the large file area.
bob gauff
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
May 28, 2024 09:36 PM
giandanielxk8
Sep 6, 2015 07:21 PM
AL NZ
Sep 4, 2015 08:39 PM
Bcrary3
Sep 3, 2015 03:48 PM
