fuel pump
Old Jun 12, 2013 | 03:00 PM
tony guy's Avatar
Default fuel pump
im having problems with my 1997 xj6 3.2 fuel pump runs when you first turn the key to prime then goes dead disconnected it from filter and turn key and fuel runs out good then stops even if you turn engine over had pump out and runs well changed relay but still only runs for couple of seconds then stops can anyone give me some ideas please only passed MOT yesterday after been off road for 6 months doing work on her not happy !!!!!!
Old Jun 12, 2013 | 10:14 PM
avioni's Avatar
I think that is normal behavior. Ur jag doesnt start? Check for spark, check if revs counter jumps while cranking, spray some carb cleaner into intake while cranking. Report
Old Jun 13, 2013 | 04:44 AM
As said, the timer at Ign ON is quite normal.
The dead pump whilst cranking is NOT.
The ECU receives a pulse from CAS (Crank Angle Sensor), and the cam Angle Sensor, this pulse keeps things running, such as fuel pump, engine, spark, etc.
The CAS is a common failure item at "about" 100k milles, no idea why, they just do. The connector for it on the front edge of the timing cover also gets "gunged" up, and causes signal issues.
The Cam Angle Sensor is not a real known failure item, but some have gone AWOL.
Also as asked, does the tacho give a small 200RPM reading as it is cranked. This is a fairly accurate indication the CAS is on the fritz if the answer is NO.
Many, many thread lately about moisture, and water in some cases, ingressing the ECU multi-pin plug/s and reeking absolute havoc.
Old Jun 14, 2013 | 11:07 AM
tony guy's Avatar
Thank you for your replies, am going to look at her tomorrow, will let you know how it goes.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
JWheeler
Nov 22, 2019 08:28 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
