Fuel Tank feed and return line connector seals
Old Oct 7, 2022 | 06:39 PM
Omid's Avatar
Default Fuel Tank feed and return line connector seals
Hi all,
I bought a gas tank online for my car and it looks like its in decent shape.
Before I install it, I thought perhaps I should replace the seals (o ring) on the fuel line connectors on the bottom of the tank just to be safe.
Does anyone know if that is possible or necessary? I cant seems to find any information about it.
Any help would be appreciated.
Old Oct 12, 2022 | 02:32 AM
someguywithajag's Avatar
yes, it is possible. Probably a good idea to replace them now especially since you have the tank out. It's a real pain to replace them later on if they leak...part number EBC9606
https://parts.jaguarlandroverclassic...e=309192397566
Old Oct 12, 2022 | 10:14 AM
Omid's Avatar
Hey thanks @someguywithajag
No wonder I couldn't find anything about it. Stuffer Pin??? what the heck kind of name is that for a gas tank line seal.
I really appreciate it friend.
Old Jan 14, 2024 | 06:51 PM
Roger Simpson's Avatar
Stuffer Pin is incorrect. I ordered them and they were wrong. The quick couplings attached to the hoses are crimped on and are 2 different sizes. tThe O'rings will age and leak! There are no part numbers for them that i could find. I bought an O'ring kit and worked at fitting the correct size! Hopefully I will get that right!
Old Jan 14, 2024 | 08:29 PM
Omid's Avatar
Actually the stuffer pin part was correct for my car. It comes complete in a nice package that you stuff into the connection hole. It worked great for me. I can see that using the correct O rings will probably work too.
Old Jan 14, 2024 | 09:54 PM
watto700's Avatar
G'day Omid,
You might find some useful info here
https://jaguarvp.blogspot.com/2013/0...placement.html
and here below.
Cheers,
Jeff.
1995XJSGuy
Sep 8, 2020 12:09 PM
jaguarguy13
XJ40 ( XJ81 )
May 1, 2016 10:43 PM
bhamilton
May 18, 2014 04:55 AM
nglshmn
Sep 30, 2012 07:28 PM
jerry conner
16
Aug 26, 2011 03:22 PM
