General Things
Old Sep 21, 2010 | 08:57 AM
sempire's Avatar
Default General Things
Looking to do a few things this weekend, and was wondering if they were straight forward. I have to pick up the Haynes Manual, but just need to see if I should get prepared.
Looking to change spark plugs, oil change, fuel filter, brake fluid, transmission fluid. Pretty easy tasks? I have never done them on a Jag before..
Old Sep 21, 2010 | 12:02 PM
Doug's Avatar
If you've done those jobs on any other car you can do 'em on your '97 X300. Nothing unique required by way of tools or knowledge. All routine.
Old Sep 21, 2010 | 12:47 PM
sempire's Avatar
Sweet...
I hate getting into a job, and then realizing it's a mission..
Old Sep 21, 2010 | 04:19 PM
Fraser Mitchell's Avatar
All that lot are reasonably straighforward, but try to get friend/wife to assist with brake fluid change. I have found it best to get friend in driver seat to pump the pedal whilst you do the necessary at each caliper; unless you have a pressure bleeding kit, of course.
For transmission fluid you have to get under the car - not a thing for cold weather !!
Old Sep 21, 2010 | 05:15 PM
TopHatChef's Avatar
Everything sounds easy enough, but purchasing the Haynes manual seeing as they don't make one for the x300. The Xj40 is similar, and Haynes does make a manual for that, but not one for the X300.
Old Sep 21, 2010 | 06:03 PM
Lumppy47's Avatar
When changing plugs make sure you use some anti siezeing compound on the threads (aluminum heads and steel plugs dont mix) also dont over tighten the plugs
Forcedair1
Sep 8, 2025 01:57 PM
xjrjag
Oct 24, 2024 03:09 PM
abonano
25
Sep 25, 2015 10:43 AM
Gatsby
Sep 6, 2015 11:52 AM
