grrr throttle
Old Apr 5, 2010 | 01:11 PM
usedjaggy's Avatar
Default grrr throttle
97 xj6 runs around 1300-1500 rpm in drive or park. Bogs or pauses on accell ? thank you in advance
Old Apr 5, 2010 | 06:40 PM
Doug's Avatar
Cleaning the throttle body is a good first step.
Old Apr 7, 2010 | 11:24 AM
usedjaggy's Avatar
thank you sounds like a good bet cant hurt
Old Apr 11, 2010 | 01:38 AM
panchostatus's Avatar
smells like a vacuum leak perhaps somewhere, intake gasket may be becoming crumbly.
good trick to try is to spray water around mating surfaces and vacuum lines and see if the idle is affected. if so, you've found your leak
jimforrest (uk)
Feb 28, 2019 06:42 PM
tomkilner
Oct 9, 2015 07:10 AM
inactualis
Oct 2, 2015 11:13 AM
Nigels420G
Mark V - X 420G
Sep 27, 2015 03:48 PM
