Have I got the wrong coil springs?
Old Oct 2, 2015 | 05:16 AM
Turbo_dash's Avatar
Unhappy Have I got the wrong coil springs?
Hello
I changed springs on my 1997' X300 4.0 Sovereign.
I used JLM12257KIT from british parts. The old springs had more coils than the new ones.
Have I got the wrong ones? If yes, what is the correct part number? Are there any heavy duty springs for this car? or someone that increases the ride height? its more like a lowrider than a car I can use daily
The Vin is 784602.
Thanks,
Thorbjørn / Turbo_Dash
Old Oct 2, 2015 | 06:20 AM
That part number comes up as the REAR on Late XJ40, X300, X308.
Unless there is a packaging issue, which might explain it,they should be correct for the rears.
Old Oct 2, 2015 | 06:31 AM
Turbo_dash's Avatar
So that part number should have more coils?
The rear is really saggy after the change. and I cant even drive over speedbumps and not damage the exhaust.
Old Oct 2, 2015 | 06:50 AM
I have no information as to the number of coils.
If they are shorter than the ones removed, they would be very suspicious in my opinion.
Aftermarket, no matter how good they appear, do make mistakes. Wrongly labelled is the most common blunder.
I would be checking very carefully with the supplier, and go from there.
Old Oct 2, 2015 | 07:01 AM
Turbo_dash's Avatar
Okay, thanks
Old Jun 1, 2017 | 07:12 AM
m5f4k8's Avatar
What's the final resolution? I'm considering the same springs and would like to know are they any good.
42Ajd
Dec 30, 2015 09:45 AM
GT42R
Canada
Nov 8, 2015 10:05 AM
copyman01
Nov 1, 2015 01:01 PM
Safari
US Central
Sep 21, 2015 09:34 AM
EZDriver
Sep 8, 2015 09:25 AM
