headlamp hi beams question...
I believe it is a bit of both. If you look at the different styles in lenses, they have a different pattern with regards to the fluting in the glass. That, plus the different bulbs you use make the light disperse differently from the low beams making it brighter.
So basically, I'm with TopHat.
Cheers,
gunlocators
Sep 30, 2015 08:05 AM
