headlamp hi beams question...
Old May 11, 2011 | 12:26 PM
MLRocafella85's Avatar
Default headlamp hi beams question...
hi can anyone tell me, do the actual headlamp make the highbeams brighter? os it is the lightbulb itself? thanks...
Old May 12, 2011 | 11:04 AM
TopHatChef's Avatar
I believe it is a bit of both. If you look at the different styles in lenses, they have a different pattern with regards to the fluting in the glass. That, plus the different bulbs you use make the light disperse differently from the low beams making it brighter.
Old May 12, 2011 | 01:51 PM
xjrguy's Avatar
My own opinion is that the brightness of the bulb is the brightness of the lamp. The difference in the main beam and the dip beam is the lensing of the lamp. The dip beam lens focuses the light lower than the main beam lens, they use the same 55w bulb.
So basically, I'm with TopHat.
Cheers,
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
sedonajag
Oct 8, 2015 07:38 PM
gunlocators
Sep 30, 2015 08:05 AM
