HELP EGR tube thread tap issue
Old Aug 29, 2015 | 01:40 PM
SD96XJ6L's Avatar
Default HELP EGR tube thread tap issue
I needed to replace my exhaust gaskets coming from the manifold to the down pipe before the pre-cats. Everything went ok, but when I went to put the EGR tubes back on, one of them will not thread back in and is slightly stripped. ARGH! What do I do? Anyone know of a solution? Thread repair kit? It's a 17mm head the same as the 02 sensors. Any input would be great!
Old Aug 29, 2015 | 02:08 PM
sparkenzap's Avatar
Is what you refer to as "stripped" the first thread on the thread nut, or is it the thread in the body? Use a triangle file to clean up the one on the nut. I have no idea for the one in the manifold.
Old Aug 29, 2015 | 03:07 PM
RJ237's Avatar
Make sure it's really stripped and not just misaligned. Getting a nut to start when the pipe is pushing it slightly is very difficult.
Old Aug 29, 2015 | 03:20 PM
SD96XJ6L's Avatar
It's definitely stripped a bit. The thread is laid down. A triangle file is a great idea. Thank you.
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
XFR_Gold
Sep 2, 2015 12:24 PM
