Help! I messed up my dash lights!
Old Feb 7, 2013 | 07:09 PM
Dan Bennett's Avatar
Default Help! I messed up my dash lights!
Newbie here so I thought I'd ask. I was toying around with the inop cigar lighter up front to see if I could make sense of what was going on with all the aftermarket wiring in there. I had no juice to either light so I thought I'd start up front for some reason....anyhow, the light itself was working. I, naively use the hot from the light on the lighter itself and then applied the cigar lighter load on it. Well. Now the light does not work when I moved it back nor do the dash lights.
Any idea what I broke?
Old Feb 7, 2013 | 10:55 PM
mikesmith2's Avatar
I would suggest you have blown a fuse. Light interior circuits normally use 5 or 7.5 amp fuses.
Cigar lighter would probably use a 20 amp fuse.
Old Feb 8, 2013 | 07:23 AM
Yeah, I checked the cigar fuse and both "instrument panel" fuses. Do you know which fuse it might be? I have all the original manuals but the fuse guide doesn't suggest anything to control that in particular.
Old Feb 8, 2013 | 08:30 AM
Doug's Avatar
Panel lighting is #2 fuse (10 amp) in the left heelboard fuse box
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Jpav27
Jul 31, 2022 06:43 AM
mrplow58
Sep 9, 2015 11:27 AM
motorhead69
Sep 9, 2015 10:04 AM
