Help Identify this part?
Old Feb 6, 2016 | 02:49 AM
Canuck XJR6's Avatar
Default Help Identify this part?
Hi Everyone,
My shop has sent me a pic of a part that needs to be replaced but I have no idea what it is. English is not the first language at the Abu Dhabi shop and all I can really get from them is "Gear Mounting".
Any ideas??? 1995 XJR
(They also need a drive shaft flex joint which I was able to identify but may not be entirely related)
All the Best,
Chris
Old Feb 6, 2016 | 07:16 AM
Malihide's Avatar
Looks to me like the Transmission Mount Bushing. If it's due for a replacement, I would look into replacing the entire transmission mount: spring, bushing, bracket, everything. Won't be too expensive and it will last you for years.
Hope this helps
Old Feb 6, 2016 | 10:12 AM
Doug's Avatar
Trevor's right....replace the bushing (#13 in the illustration) and the springs, and the spring seat insulators
Engine Mounting Bracket-Rear-4.0 Litre Supercharged-Automatic - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK
Replacement springs were uprated a bit so as to make the entire affair a bit less loose and bouncy. But, if you're on a budget, it isn't essential
Old Feb 7, 2016 | 05:52 AM
countyjag's Avatar
Agree with Doug. Not a big job, and as long as you replace the foam bushing, the rest is optional.
Old Feb 8, 2016 | 01:20 AM
Thanks Trevor, Doug and countyjag!
The link to the part assembly pic was awesome. Thanks DD
All the Best,
Chris
Milowokie
Audio/Visual Electronics
Jan 9, 2017 07:09 PM
XJsc-guy
Jan 12, 2016 12:37 PM
al_roethlisberger
Jan 11, 2016 01:17 PM
Skid Mark
Nov 4, 2011 08:22 PM
Mayor111
Dec 20, 2010 02:33 PM
