Help in identifying someting
Old Aug 23, 2025 | 08:10 PM
Gottabekidding's Avatar
Default Help in identifying someting
I do almost all the work on my cars.
Foreign, domestic, old or new.
This is my first Jaguar, probably my last.
I don't get rid of cars.
Still got my '87 Corvette convt, '91 Firebird GTA, '93 Camry, etc.
With that said, finding parts or even part numbers for a 30-year-old jaguar sometimes has me beat.
A/C hose assembly URO P/N MNA7310 AE
has a servicing port in the middle of it. That screws onto the hose assembly.
I require just the servicing port - not the whole hose assembly
Anyone know if i can get just the servicing port, not the whole assembly???
Old Aug 24, 2025 | 03:38 PM
Parker 7's Avatar
One of the hoses with the 2 wire freon pressure switch on it was superseding by a different part # with the freon switch negated by a TSB linked below
14-04
You can still use a hose with the switch installed as not leaking , just wiring jumper
Someone did just go through the service port only part recently and though there should be an industry standard turned out to be Delco as a tiny dimension change if I recall correctly
Old Aug 24, 2025 | 05:48 PM
motorcarman's Avatar
The ports are easily replaced.
https://www.ebay.com/itm/222969032021
https://www.ebay.com/itm/22572239995....c101465.m3507
and the tools so you do not damage the fittings.
Amazon Amazon
AlexJag
Jul 3, 2024 12:34 PM
wsn03
Jan 30, 2022 02:56 AM
bcucharternet
Jul 21, 2016 09:32 AM
cdaubs
E type ( XK-E )
Sep 1, 2012 02:15 PM
J4g-off
XJ40 ( XJ81 )
Nov 14, 2010 08:17 AM
