Help OBD port 97 Vanden Plas
Old Apr 11, 2012 | 09:52 PM
Wew256's Avatar
Default Help OBD port 97 Vanden Plas
Well hello to all,
Ive had my 97 VDP for about 3 years now 120,000 miles on it never really had time to drive it heavy. I just changed out speakers and was about to update the stereo.
And wouldnt you know check engine light on took it to local auto store of course they cant find obd, so get down with my flash light and commence to searching. Some info says the odb port should be between steering column and center console, others above the hood latch, others around trim under dash.
Anyone with a 97 VDP know where it is at for sure? And Im assuming OBD2 protocol? All responses greatly appreciated... Thanks Will
Old Apr 12, 2012 | 12:13 AM
Doug's Avatar
On mine it's right about where the bottom edge of the dash and the vertical plane of the console come together
Old Apr 12, 2012 | 09:23 AM
Roger95's Avatar
"On mine it's right about where the bottom edge of the dash and the vertical plane of the console come together"
My '96 VDP as well
Old Apr 12, 2012 | 11:15 PM
Wew256's Avatar
Default thanks
Thanks fellas mine had got tucked off in the trim pretty deep and had to get under and pull it out think I brushed across it twenty times just wasnt looking far enough in there.
Appreciate all the help fellas and have a good one.
carl purchase
Oct 14, 2015 06:14 PM
JungleJonny
Oct 5, 2015 03:52 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
42Ajd
Sep 26, 2015 07:04 PM
