HELP! Rear Sway Bar Conversion issue
Old Oct 4, 2015 | 11:30 PM
SD96XJ6L's Avatar
Default HELP! Rear Sway Bar Conversion issue
I bought a rear sway bar and bracket from a member here and was told it came with everything needed to convert. I am stuck on one missing part though. The bracket for the XJ6 without sway bar has a much larger hole for the mounting bolt. The 308/XJR bracket has a smaller diameter hole. I am scouring Genuine Jaguar Parts and Jaguar Accessories for classic Jaguars from Jaguar Heritage Parts UK to see what the difference is and part # if the member can't or won't send me the proper bolts. Check it out below. Has anyone converted to a rear sway bar and run into this issue?
The non-sway bar bracket has much larger diameter inner openings. The X308/XJR bracket for rear sway bar has much smaller openings. I need to figure out the part # situation if need be.
This is the larger diameter bolt. There is a hex on it that screws into the back of the diff housing behind the black bracket which sandwiches between the mount and the diff.
Old Oct 5, 2015 | 05:59 AM
dfieldsend's Avatar
The X308 has a different rear suspension setup to the X300, you need the XJR tie bar from an X300, not an X308
Old Oct 5, 2015 | 09:48 AM
44lawrence's Avatar
Yes I installed a factory rear sway bar along with the thicker front bar that came from a 95 donor car a few years back in my 95 VDP . I don't remember all the in's & out's of the installation but it was a straight forward job, everything was bolt in with no mods. a lot of parts to change though. I dropped the IRS in the process , cleaned & replaced all worn parts, Was it worth it in regard to handling & expense/labor ? NO, IMOP, If your IRS needs to be dropped for any reason & you get the sway bar & ALL the parts very cheap, do it. Remember the matching thicker front bar should be changed also.
Lawrence
XJ8JR
65
May 21, 2022 01:52 PM
SCMike
Nov 25, 2015 07:55 AM
Marque
Oct 11, 2015 05:59 PM
dmatthewman
Sep 30, 2015 10:10 AM
beady
Sep 28, 2015 10:20 AM
