help replacing crossbeam support
Old Sep 5, 2013 | 02:54 PM
avioni's Avatar
Default help replacing crossbeam support
hi, has anyone replaced the 2 upper rubber supports for the front crossbeam? im looking for tips or guide on doing the replacement job on a 1997. although it looks like a simple remove and install im pretty sure the torx screws will give me trouble
Old Sep 5, 2013 | 03:32 PM
BlackX300VDP's Avatar
Haven't done them in years! The torx bolts are a little tricky as I think there is some locktite on the threads and it is hard to get a straight shot on the bolt. You must have the ability to lift the body up while the subframe lowers. Loosen the rear subframe bolt so that bushing doesn't bind and tear. The new mounts go into the upper frame member of the unibody about an inch or so. I couldn't find the repair in my version of the repair manual. It is relatively straightforward. I don't recall any tricks or things to watch out for beyond what I mentioned with lifting the body from the subframe.
Let us know how you make out.
Old Sep 5, 2013 | 05:28 PM
b1mcp's Avatar
As mentioned above there are locating lugs on the V mounts that go in to the chassis. The tricky part I found was lining these up. As it is likely that you have the rear mounts still in place but just loosened (as recommended above) then the subframe is pivoting on the rear bush bolts. That means the V mounts are not at the right angle to go in to the chassis.
I needed an assistant to slowly raise jack under the subframe while I levered the V mount to be parallel with the chassis. Ideally have another assistant lever the V mount on the other side at the same time. Bit of a team game really.
Old Sep 5, 2013 | 07:26 PM
avioni's Avatar
Why not slide it in place while the subframe is down and then raise the frame and bolt the four torx?
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
KarimPA
Sep 12, 2015 08:15 AM
Holden
Sep 5, 2015 03:29 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
