How to clear codes and reset TPS adaptations in IDS 118.5?
Old Nov 4, 2014 | 08:20 PM
juha_teuvonnen's Avatar
Default How to clear codes and reset TPS adaptations in IDS 118.5?
I got my grabby hands on a genuine Ford VCM and IDS 118.5 Patch 11 (the latest available for that version IIRC). I can read the codes just fine. This includes TCM, ABS and others. For some reason I don't see an "erase" button on the right side of the screen like I do with Ford/Mazda IDS. How do I erase the codes?
Also, How to I reset the adaptations for TPS? Which menu is this buried in? Any pointers to IDS Jag manuals or training materials would be very much appreciated.
Old Nov 5, 2014 | 08:09 AM
b1mcp's Avatar
This is from memory so I might miss something.
Erasing codes is a 2 step process. First click on the code or module you want to erase. A button appears on the right of the screen - looks like an eraser on the end of a pencil. Click that. That adds it to the list of things to be erased. Select all of the codes or modules you want.
When you have selected something to erase another button should appear but I can't remember what it looks like. This lets you actually clear the codes selected.
For TPS, click on the Tab at the top of screen with the Car/Spanner Icon. Select “Setup and Configuration”, then expand “Engine and Transmission”.
Old Nov 6, 2014 | 09:46 AM
Awesome, thanks!
Old Dec 1, 2014 | 08:37 AM
aldol's Avatar
what cable do you use?
i seem to undertsand that the mongoose only supports 2005 and up
i also have a 1995 xj6 that was my mom's (RIP)
Old Dec 1, 2014 | 02:40 PM
I had a Mongoose knock off from British Diagnostics. I was unable to get it to work with my 1995 X300. It is rumored to work with later models but I have no confirmation of that.
I bought a genuine ford VCM (not a clone). So far it has been working great with IDS 118.5. The only issue is, frankly speaking, my lack of experience with IDS.
hafren
23
Jan 3, 2025 11:26 AM
St.Regis
Oct 4, 2024 12:07 PM
99xk8guy
May 28, 2024 09:36 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
mrplow58
Sep 9, 2015 11:27 AM
