How do I reset the Check Engine Light on my 1995 VDP???
Subscribe
Nov 3, 2009 | 06:46 PM
ED:
Not to be a wise ***, but you might plan to fix the problem first. That would require you scan to find the code, right? Most any OBDII reader does fine. Although the '95 is not certified as OBDII, the system is actually OBDII. The '95 and '96 ECUs are connector interchangable.
You can find the code list via google .. or post back here for diagnostic help.
Reply 0
Subscribe
Currently Active Users (1)
