How much antifreeze?
Old Aug 16, 2013 | 12:03 AM
rob20087's Avatar
Default How much antifreeze?
Hi, my 4.0l engine runs a little cool. So will change the thermostat which is the most likely culprit. May as well flush the system while I'm at it. So am wondering how many litres of antifreeze to add. Couldn't seem to find an answer searching the threads. Just another thing. Where are the bleed screws? Thanks. Rob.
Old Aug 16, 2013 | 12:22 AM
trucknetjack's Avatar
there is one at bottom of rad,and on the block,read that they like a 50/50 mix others will give more precise details soon.
got to do mine soon.
Old Aug 16, 2013 | 07:32 AM
aholbro1's Avatar
I belive it is a 12 system. So you want 6L anti-freeze. My radiator has no draincock. Could not find the block drain as shown in the pubs. I drained by disconnecting the lower hose. Got about 2 gals. Topped up with distilled and brought it up to operating temp. Drain/fill/run. I had "good color" after 10 gallons of distilled.
There are no bleeders.
ejjbee
Jan 26, 2019 11:53 AM
drpsmith
Oct 16, 2015 08:23 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
kevo
Sep 8, 2015 09:45 AM
JanuarXKR
General Tech Help
Oct 14, 2009 09:44 PM
