Ignition coil location???
Old Oct 29, 2008 | 06:11 PM
christian's Avatar
Default Ignition coil location???
Not to be stupid but were is the ignition coil on a 97 xj6?? i need to replace it..
thanks!!
Old Oct 30, 2008 | 09:59 AM
ken@britishparts.com's Avatar
Default RE: Ignition coil location???
You have six of them. One on each plug. Remove the plastic cover from the top of the cam cover. You will see them all.
Old Oct 30, 2008 | 11:59 AM
christian's Avatar
how do i tell which one is bad???and i just order what i thout was a coil that when to all six plugs
Old Oct 30, 2008 | 12:56 PM
You can unplug them one at a time. The one that doesn't make a difference in the way the engine runs is bad.
Old Oct 30, 2008 | 01:00 PM
KAZsam's Avatar
Or Ken, you can have someone crank the motor as you pull each coil off the plug and stick the coil to your tongue. The one that doesnt' send you across the garage is the bad one.
Old Oct 30, 2008 | 02:08 PM
LMAO!
scooternva
29
Mar 25, 2025 12:45 PM
cissdm
May 3, 2016 06:02 AM
copyman01
Nov 1, 2015 01:01 PM
Clamdigger
Sep 12, 2015 03:43 PM
jagent
Sep 12, 2015 01:40 AM
