Inertia switch question?
Old Nov 1, 2012 | 06:50 PM
JagfanNYC's Avatar
Default Inertia switch question?
I was driving this evening going around 20mph. Then I hit a big pot hole on the passenger side, right after that the car beeped and turned off. No warning lights came on. Right after that the car wouldn't start I thought I did some great damage. No warning lights came on just like radio and interior dome light. So I knew it wasn't the battery. I searched a little and read about the inertia switch, I eventually found it pressed it. Then the car started! So my question is could the inertia switch make it so the car wouldn't even crank? I thought I had a loose ground.
Old Nov 1, 2012 | 07:19 PM
I am assuming an X300 ?????.
Not sure what it kills on mine, never tried it.
On the XJ-S it kills the fuel pump circuit. The S2 XJ12 does the same, and also the starter circuit, not sure if that is by design or just old age.
I reckon you got other gremlins, but if its running and doing what it should, dont mess with it.
Old Nov 1, 2012 | 08:43 PM
JagfanNYC's Avatar
I hope I do not have any gremlins. When I got home I restarted the car and it did start up. One thing that was odd was when the car wouldn't start when I put on the headlights only the passenger side light would come on. When I hit the high beams then they would all come on. Then after I pressed the Inertia switch both lights came on
Old Nov 2, 2012 | 04:13 AM
Bugga, I need a drink, so do you.
The inertia switch has NOTHING to do with headlights, full stop.
I would start by checking some earth wires, and the main battery cable connector at the +ve battery terminal.
Something else is loose, and caused those outages.
Reading my handbook and other stuff I got, the inertia switch is "fuel circuit safety OFF", which was my thoughts in the first place.
Old Nov 2, 2012 | 07:53 AM
Brutal's Avatar
The inertia switch kills fuel pump and yes a pothole or a wheel weight coming off the wheel will trip the inertia switch
Old Nov 2, 2012 | 09:18 PM
JagfanNYC's Avatar
I drove again today and the car drove normal.
Old Nov 5, 2012 | 11:41 PM
sparkenzap's Avatar
I'm betting the headlamp is intermittent and will fail completely soon,
Forcedair1
Sep 8, 2025 01:57 PM
tonyforman
Sep 10, 2015 07:23 PM
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
laserguy
Sep 3, 2015 02:02 PM
