Input air sensor reading +40 OBD2
Old Jun 13, 2021 | 05:13 AM
Matto1965's Avatar
Default Input air sensor reading +40 OBD2
Hi all I bought a new OBD2 and it reads better on x300 4.0na . I see now that my IAT is reading +40 c. Unplugged I get -40 c. I put a potentiometer in line to increase resistance and got -18 c turn pot and got -19/20. I am assuming that my IAT is fried. Any thoughts?
Old Jun 13, 2021 | 06:59 AM
Vee's Avatar
Vee
Yup. I would think that would need to be replaced. Easy and cheap.
How's the coolant temp sensor? You may want to got 2-0 on cheap and easy....
Old Jun 13, 2021 | 12:06 PM
Parker 2's Avatar
The inlet air temp and engine coolant temp sensors are thermistors that when unplugged are not powered as they should be
They can be calibrated against a chart on page 86 and 78 as your meter should be powering them if you use a 9 volt battery powered meter
http://www.jagrepair.com/images/Trai...20-%202000.pdf
TGraves
Aug 30, 2020 01:54 PM
jaguar51
Jul 19, 2017 11:54 AM
Elrod the Albino
Jan 13, 2011 01:57 PM
richcurt07
XJ40 ( XJ81 )
Oct 12, 2010 10:53 PM
electraglide1600
Sep 13, 2010 01:16 PM
