Instrument Cluster
Old Nov 25, 2017 | 02:44 PM
paulZ's Avatar
Default Instrument Cluster
anyone know a reliable place to send the unit for new displays and calibration?
Old Nov 25, 2017 | 09:14 PM
Qvhk's Avatar
What problems do you have on your instrument cluster? Dimmed lights or inaccurate reading? Light bulbs are easy to replace but calibration is an entirely different matter; e.g. speedometer reading is affected by many issues. Anyhow used ones are dead cheap hence saving the trouble of fixing yours.
Old Nov 26, 2017 | 12:46 PM
paulZ's Avatar
The digital readout is fading, the rest is OK I will check into used units. thanks
Old Nov 26, 2017 | 01:07 PM
Qvhk's Avatar
Look out for X300 X40 Display Unit JLM1932 (see example on eBay here) but new ones are no longer available, and buying the whole instrument cluster does not cost much extra although shipment might hurt.
Old Mar 21, 2018 | 06:20 PM
paulZ's Avatar
Default Thank you!
I found one at the Upullit
yard, amazed at how easy the unit is to remove
