Interior lights not working after headlining changed
Old Sep 19, 2014 | 01:52 PM
Juliesjag69's Avatar
Default Interior lights not working after headlining changed
Ok guys, finally managed to replace the headlining, had the rear window removed and tinted, while it was out changed the headlining. Blew the fuse for the interior lights, curtsey lights map lights and visor lights. replaced the fuse in the R/H side fuse box but still nothing. Anything else to look for or do?.
Old Sep 21, 2014 | 06:38 AM
Anyone???
Old Sep 21, 2014 | 09:56 AM
aholbro1's Avatar
Did you remember to plug the overhead console back in?
Maybe search the electrical diagrams to see if another fuse is related?
Old Sep 25, 2014 | 05:38 PM
theJPster's Avatar
You mean the one under the rear seat? That's what blew in my car when I did the headlining. Spent two days swearing before I realised I was looking on the wrong side. On a UK car it's driver's side.<br />
<br />
If that fuse has power and the connectors do not then you need to start chasing wires. But if all the lights have gone I'm pretty sure the fuse is the problem. The visor lamps, iirc, are ignition, fuse, switch, bulb, ground. It must be one of them at fault!
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
johnnie ryall
Oct 19, 2015 09:44 PM
SatanClaus
US Southwest
Aug 31, 2015 11:45 AM
SatanClaus
Aug 29, 2015 09:15 AM
