Intermittent heat.
Old Feb 8, 2024 | 04:49 AM
PBoudr's Avatar
Default Intermittent heat.
A little bit of a weird problem. '97 X300, VDP. Heat had been working fine since I got it 6 weeks ago. This past weekend I ran to the store and noticed it was still blowing cold air even after the temperature gauge came up to normal temperature. After running into the store for about 15 minutes I came out and when I started it up it was blowing warm again. Then this week on the way to work, same thing, cold air after the temp gauge came up to normal. I pulled over at a gas station, turned the car off and then back on and got warm air. It must be the heater control valve I'm thinking? Or maybe the louvers under the dash. I did cycle through the various positions of the vents and that didn't help.
Old Feb 8, 2024 | 07:31 AM
Parker 7's Avatar
There is a easy bite test that you press buttons on the climate control panel
See page 110
This Doc was written during the later X308 time but the same Denso climate control system
There is a list of codes in a TSB
14-10 (jagrepair.com)
T703 BOOK (jagrepair.com)
Someone made a Youtube video
Most likely it is the brushes in the electric motor / pump assembly that circulates hot coolant to the heater core ( matrix ) , cheap and easy fix
Old Feb 8, 2024 | 03:12 PM
PBoudr's Avatar
Thanks, I'll try that out.
Old Feb 8, 2024 | 03:42 PM
Parker 7's Avatar
.15" x .15" x .35" BRUSH 33A (eurtonelectric.com)
Some have replaced the motor / pump assembly with a Bosch unit
Old Feb 8, 2024 | 08:22 PM
PBoudr's Avatar
Thanks! Do these look like they'd work, maybe with some slight modification?
Amazon Amazon
Old Feb 8, 2024 | 09:02 PM
Parker 7's Avatar
4mm X 4mm X 10mm
I can be wrong but I think it is too small
Old Feb 8, 2024 | 11:02 PM
Parker 7's Avatar
is
3.81 mm X 3.81 mm X 8.89 mm
jomo
Feb 27, 2024 07:55 PM
Doug
Sep 7, 2019 01:24 PM
davchr
May 11, 2018 05:18 PM
fallout
Jul 25, 2012 06:18 AM
Boomer from Boston
Jan 24, 2012 01:16 AM
