intermittent remote function..
Old Jan 17, 2012 | 10:59 PM
97x306's Avatar
Default intermittent remote function..
hi everyone,
am I the only one who has a very intermittent remote operation or is is a common x300 anomaly?
both little batteries are new (and correct type), and remote is programmed and it works, although quite intermittently.
the green/red lights on the remote do come on when buttons are pressed, and sometimes it opens/closes the doors (5%) but most often it does not (95%)
any idea why? my other cars remotes work really well even 20m from the car...
failing that... I may install an off the shelf security system,... what kind of bypass module do I need to bypass the OEM setup? what kind of OEM security system is this? (VATS, Passlock, Transponder, etc?)
thanks
Old Jan 18, 2012 | 02:48 PM
etaent's Avatar
i too had that issue, what i did was i got some contact cleaner at radio shack and opened the fob up and cleaned the entire thing. I cleaned and dried the buttons and after that its been working great ever since! I wont lie, 5% of the time i will have to hit the button twice to get it to unlock or lock but these cars are already 16 years old so its a miracle it works in the first place! hope this helps!
Old Jan 18, 2012 | 07:31 PM
aholbro1's Avatar
Mine too...but it's about 5% doesn't work vs. 95% does. I'll try cleaning its innards as ETA suggested if it gets more bothersome,
Old Jan 18, 2012 | 11:17 PM
97x306's Avatar
thanks,... I opened it up, but I don't see anything dirty inside ...
there are 2 small microswitches (lock/unlock), and as soon as I touch them, the corresponding red/green lights do come on, indicating connection is decent
I am still toying with the idea of an off the shelf alarm unit if installation is not too involved...
Ferdie
Nov 26, 2018 05:42 AM
Moghut
Oct 1, 2015 01:55 AM
Listers
Sep 30, 2015 07:45 AM
zdrapec
Sep 25, 2015 05:49 AM
