Jag '96 VDP Driver low beam not illuminating
Old Dec 12, 2018 | 11:51 AM
Col_T's Avatar
Question Jag '96 VDP Driver low beam not illuminating
Noticed flickering on low beam driver's side & installed new bulb...now not illuminating at all...all other lights function...did obvious like check ground/clean contacts at fuse box connections (there was some corrosion but cleaned)/fuses etc ... small pilot bulb illuminates in the driver's side lamp but not main bulb (bulb checks OK)...any suggestions or possibly an electrical schematic for that '96 VDP or XJ headlamp electrical system? Thanks very much
Old Dec 12, 2018 | 07:46 PM
Lady Penelope's Avatar
Page 107
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
Old Dec 13, 2018 | 01:02 AM
SleekJag12's Avatar
In particular, Relay #2, LH side is the one to check ("dipped beam" is British terminology for low beam). Swap it with #1 (all those relays are the same). The relays unhook from the frame with wires attached. Keep in mind the relay itself is difficult to pop out as they are meant to be weatherproof. And they are dirty.
Old Dec 13, 2018 | 03:25 AM
Those British terms taunt me deeply
If you flip them upside down and spray them with penetrating oil and a rag to grip them it helps
I found some of the wires damaged under there for whatever reason
hawaiiboyy
Apr 13, 2014 04:44 PM
cybercg
Sep 30, 2013 03:43 PM
jnole
Mar 13, 2013 09:02 PM
mlewisfwa
May 13, 2008 04:57 PM
Jan 2, 2007 04:37 PM
