Jaguar X300 XJ6 cruise control installation
Old Jul 3, 2024 | 09:37 AM
pilchypilch's Avatar
Default Jaguar X300 XJ6 cruise control installation
Hello again everybody. Just wanted to thank everyone who took the time to reply to my last query before I started this thread.
So, I have a 1996 XJ6 3.2 Executive. I know its not the fanciest model but its in great condition and i am looking at ways to improve on it.
So my next query is whether anybody knows how difficult it might be to install cruise control to the car.
I know there are after market systems you can buy to install yourself, but I would quite like to keep it as original as possible with original switches etc from a donor vehicle.
Would anybody on here know which parts I would need to purchase and whether there is a huge amount of installation work required.
I suppose I could purchase a donor car with it already installed and dismantle it. But it seems a bit excessive. And I currently don't have the space to park another jag.
any information is greatly appreciated.
Rich
Old Jul 3, 2024 | 10:25 PM
Darkhorse's Avatar
I've never installed a cruise control but I will offer my two cents. My thinking is it could be pretty complicated to add an OEM setup from a donor car. Personally, I would lean towards an after market kit if I needed to add cruise control to one of my cars. Summit Racing has quite a few after market choices. A hybrid option might be worth considering. Get an aftermarket kit and see if you can track down the Jaguar control panel. You might be able to wire the after market components to the Jag controls so from the interior it appears stock.
Old Aug 22, 2024 | 04:52 PM
macribor21's Avatar
For power steering (small reservoir on the right) use some variation of Red Automatic Transmission Fliud. Should say Dexron on it. Regular power steering fluid is not correct for this car. The coolant is now supposed to be the orange stuff I believe. Originally it was something different but it caused issues with the heater core. At the store it would have an orange cap.
Old Aug 24, 2024 | 04:21 AM
katar83's Avatar
Its very simple to move cruise control from one car to another, think I've done it three times now.
Speed control actuator 1 DBC2641
Nut - actuator to bracket 1 FN108041
Washer - actuator to bracket 1 WA106041
Speed control bracket 1 EBC9695
Screw - bracket to body 1 FS106141
Sliding link 1 NBB319AA
Shoulder bolt - link to actuator 1 EAC8167
Washer - shoulder bolt 1 WL104001
Nut - shoulder bolt 1 NH104041
Retaining pin - link to abutment bracket 1 NBC3121AA
Washer - retaining pin 1 WA105001
Circlip - retaining pin 1 C14350
Abutment bracket (already fitted) 1 NBC2010AA
Screw - abutment bracket to 1 FS106201
Speed control switch (fascia) 1 LNA6227BA
Speed control resume switch cap 1 JLM12058
Speed control pump 1 LNA1955AA
Dump valve 1 LNA1950AA
Vacuum hose 1 DBC153
T-piece 1 DBC167
Vacuum hose 1 ???
Vacuum hose 1 ???
Cruise control ECM 1 LNA1940AC
Flanged nut - M8 1 FN108041/J
Flanged nut - M6 2 FN106041/J
Brake switch (speed control) 1 DBC10800
When taking parts of donor car, you will need switches, cruise module, link(to bridge an empty plug with yellow wires in the wiring behind ECU) and brake switch(if yours is early x300, later ones will have correct brake switch already) from inside the car and all the throttle bits and a pump in front of left wheel with all the bits connected to it under bonnet.
Not a difficult job, certainly helps if you've got smaller hands or you're generally a small person as some parts are of course stuffed in with barely any access. Think it took me approx. 2 hours to transfer it from my previous X300 to current one. If you've got any bulbs out in the instrument cluster, that will be the time to replace them too.
You can see all the bits here too:
https://blackcherryjaguar.com/produc...-retro-fit-kit
300GBP for the whole kit in UK.
Old Aug 27, 2024 | 04:29 PM
macribor21's Avatar
Originally Posted by macribor21
For power steering (small reservoir on the right) use some variation of Red Automatic Transmission Fliud. Should say Dexron on it. Regular power steering fluid is not correct for this car. The coolant is now supposed to be the orange stuff I believe. Originally it was something different but it caused issues with the heater core. At the store it would have an orange cap Tutuapp 9Apps.
I have a 13 year old car which I'm planning a road trip into Europe with this summer. The trip may end up being around 2000 miles and involve some autobahn.
sturner
Jun 17, 2023 05:01 PM
Choppa
Sep 21, 2019 02:13 AM
Harry Dredge
May 1, 2016 07:23 PM
thuffner3
Jun 7, 2011 05:30 AM
dutch
Aug 8, 2010 03:12 PM
