Leak at differential where axle flange mounts
Old Dec 18, 2012 | 04:51 PM
EZDriver's Avatar
Smile Leak at differential where axle flange mounts
My rear axle flange is leaking. Would like to know what is involved in replacing the seal. Is it worth changing the fluid and cleaning the breather to see if that stops the leaking? And also where is the breather and how difficult is it to clean.
I am considering getting a pretty good indy near by to do the work. Does this require a lot more experience than he and I would have?
Thanks guys.
Old Dec 18, 2012 | 05:33 PM
Straight6DOHC's Avatar
This is not a bad or expensive job for the diyer. You do need access to a 12 ton press though. It's the kind of job that after I do it I can stand back and say - 'I did that!'. Generally termed 'diff output bearing' You should get plenty of info here or elsewhere on the web.
Old Dec 18, 2012 | 06:22 PM
Adding to that.
I would clean the breather (known issue with these cars), and it is located on the diff backing plate, RH side waaaaaay up there above the fill hole. You will possibly "feel" it more than actually see it. Get some p/pack degreaser/brake cleaner/whatever, and a tooth brush and go for it.
I did mine, took about an hour, but I am slow, and then I changed the diff oil with Synthetic oil, washed the output shaft area (it was only damp with oil), and checked again a month later, DRY.
That is always my first suggestion, CLEAN oil/fluid in the suspect component, it does wonders mostly.
Old Dec 18, 2012 | 06:24 PM
I've taken your question as referring to replacement of the the pinion flange oil seal and not the bearing.........?
Here's the procedure for replacing the seal:
X300 - Driveshafts & Final Drive.pdf
The Parts Manual illustration makes the layout a bit clearer:
Old Dec 18, 2012 | 09:00 PM
mmeawad's Avatar
https://www.jaguarforums.com/forum/x...st-seal-55403/
Old Dec 19, 2012 | 09:46 AM
EZDriver's Avatar
It is on the right side and it looks like it leaks from under the retaining plate. Looking at the above diagram it appears that the "O" ring is leaking. And it looks like a major job to get to that. I'm open to suggestions here.
Old Dec 19, 2012 | 10:35 AM
RJ237's Avatar
I have the same problem. The previous owner paid to have both sides done a couple of years ago, but I think they only did the right. Or maybe the shaft is scored. I will replace this winter sometime. It's not a big job, but I'm in no rush to get my hands dirty right now. Differential Bearing/seal Kit - DIFF.KIT.X300
Old Dec 19, 2012 | 01:13 PM
EZDriver's Avatar
It seems that we keep following in each others foot steps. You go first and let me know how it goes.
FrickenJag
Jun 16, 2025 02:15 PM
rusty37
Apr 5, 2020 07:40 PM
Bill Swift
Mar 31, 2017 01:33 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
AtholC
Sep 9, 2015 09:07 PM
