Leaking cooling fluid / water
Old Aug 12, 2010 | 11:18 AM
axelaxel's Avatar
Default Leaking cooling fluid / water
A few days ago my car started to leak cooling fluid / water. It leaks more and more for each day i drive it. As it is now i can drive circa 10 KM before the level is under minimum and the light signal starts to indicate that the level is under minimum. I can see that it drips water under the car, but i can
unfortunately not get a good look under it, and see where it came from. Is it anywhere that there is a big chance to locate the leaking, or could it be anywhere? Thanks for answers
Old Aug 12, 2010 | 12:13 PM
Hi, is this the 96? (mind you not much difference).
It could be any of the hoses, or the expansion tank etc etc.
Unfortunately difficult to pinpoint over the Internet.
If you can't get under the car, can you at least grope your way along the hoses that you can see, and discover if your fingers come away wet.
There is a hose under the intake manifolds that seems to appear from time to time.
Coolant leaks are usually a visible problem.
If you can't find it, then I would take it to a garage to get it raised for a look see.
If you crack open the expansion tank cap you should at least depressurize the system enough to get you there. Set out with it full and with a cold engine.
Old Aug 13, 2010 | 02:53 PM
axelaxel's Avatar
It was one of the hoses. It was a big hole, but now its replaced and does not leak anymore. Thanks
Old Aug 14, 2010 | 04:50 AM
Cadillac's Avatar
Nice, glad you fixed the leak
Old Aug 16, 2010 | 01:21 AM
axelaxel's Avatar
Me too
Old Jan 20, 2021 | 11:31 AM
Excalibur2012's Avatar
I just discovered the leak in my newly acquired 77 XJ6C. The Expansion Tank had a pin hole from corrosion about half way up the visible side. Temporary patch is a large enough sheetmetal screw to fit snugly and JB Weld. Find that a used original is about 120 Quid, a new one over 300 and a new aluminum generic about 20 USD. Hmmm !
susu
25
Apr 13, 2022 06:52 PM
mat32essex
Jun 1, 2019 08:48 AM
PeterG
Apr 21, 2018 07:54 PM
Tijoe
16
Apr 6, 2014 09:38 PM
devilishdesigner
Jan 30, 2013 05:51 PM
