Location of Door Lock Relay
Old Sep 18, 2012 | 03:56 PM
XJ6Aficionado's Avatar
Default Location of Door Lock Relay
Hello Group,
Does anyone know the location of the relay used in the door lock system of the '95 XJ6? I have the early '95 XJ6 that has no glove box.
Thanks Everybody,
Carl
Old Sep 18, 2012 | 05:23 PM
Originally Posted by XJ6Aficionado
Hello Group,
Thanks Everybody,
Carl
According to the Vehicle Care Handbook, in the passenger compartment behind the left hand side heelboard below the rear seat.
Relay has a Violet coloured case.
Attached Thumbnails Location of Door Lock Relay-x300-lh-heelboard-fuse-box.jpg
Old Sep 19, 2012 | 08:47 PM
Default Identification of Relays
Graham,
Thanks for the tip. I removed the panel you indicated and saw three separate violet-colored cases that contain relays. One relay case in the center (containing two relays) and one case on the left and one on the right. The left and right cases contain one relay each. The identifier on the relays is LNA 6705 AA. Does your information identify which of these relays is associated with the door lock system?
Thanks much.
Carl
99xk8guy
Sep 29, 2025 10:51 PM
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
XJsc-guy
Nov 23, 2015 01:56 PM
leep123
Sep 12, 2015 06:53 PM
