Looking for long lugs replacement
Old Sep 12, 2021 | 06:53 AM
cdma's Avatar
Default Looking for long lugs replacement
Over the last few years anytime a jag comes in to You Pull It I go to get the lugs, among other parts. Well rotating my tires yesterday, which I do myself because I have had too many strippers or dented, I stripped three more. Does anyone have a recommendation for the chrome longs? If I was able to find them I may no longer need to do it myself.
Old Sep 12, 2021 | 07:42 PM
cdma's Avatar
It appears that this is a common issue. I have gone through every thread and no one has seemed to find a replacement for the long lugs for the dimple rims. I guess I will have to continue to stock up at You Pull it.
Old Sep 13, 2021 | 03:48 AM
Cafcpete's Avatar
These might do the trick
https://www.berkshirejagcomponents.c...CmdYQAvD%5FBwE
Old Sep 13, 2021 | 07:01 PM
cdma's Avatar
Those would work but they are just original lugs. Trying to get away from those since as they age they become a problem thanks for you response
Old Sep 14, 2021 | 02:16 AM
Cafcpete's Avatar
I am in the UK and use here for odd nuts.
Welcome to Speed Shack
It may be worth emailing them and discussing options.
Old Sep 14, 2021 | 01:46 PM
xalty's Avatar
Amazon Amazon
it's like 5mm longer
Old Sep 14, 2021 | 06:36 PM
cdma's Avatar
Hate to ask this question but....Have you used these? It just looks like the washer will be too far up
Old Sep 14, 2021 | 07:09 PM
xalty's Avatar
no
Old Jul 16, 2022 | 09:34 AM
cdma's Avatar
Sorry to bring this back up but still looking for replacements. Getting tired of having to replace them because the aluminum cap expands to where you need a 23mm socket, or it just strips. Luckily I have a bucket of them, but not sure how long that will last. I have already gotten the spinning lug and was able to get it off, but it was a PITA. I am not sure what is causing the lugs to do that but they are crap and I would like to get some steel lugs.
Old Jul 16, 2022 | 09:48 AM
xalty's Avatar
your impact socket is worn out. im whaling on these all the time they hold up fine.
the 19mm on the newer ones is a real POS though
Old Jul 16, 2022 | 11:46 AM
cdma's Avatar
Not using an impact until the last time since I could not get the lug wrench over them.
Jaguarstyper
Sep 6, 2019 02:27 PM
Bethany Cornelison
May 20, 2013 10:28 AM
Drb007
Mar 19, 2013 03:57 PM
qwiketz
Aug 17, 2011 01:04 PM
