LOUD Squeaky Sound, HELP!
Old Sep 21, 2016 | 01:54 PM
Jorge Dias's Avatar
Post LOUD Squeaky Sound, HELP!
I own a Jaguar XJ6 1995 and it always has a LOUD squeaky sound, Ive replaced both belts and the only time it stops squeaking is when I put on belt conditioner but then in around 10-15 mins it starts squeaking again so I have to be putting belt conditioner all the time. Any Fixes?
Old Sep 21, 2016 | 07:55 PM
motorcarman's Avatar
Sounds like you might need a crank damper rebuild.
There are many threads about marking the pulley and see if the marks move from alignment. This is the way I check the damper.
Damper Doctor
or
Dale Manufacturing
bob
Old Nov 3, 2016 | 09:34 PM
fmfz12007's Avatar
Check your harmonic balancer , all you'll need a piece of white chalk and instructions you can easily find on the Web . If you need a recommendation of a rebuild I'll send it to you .
andybsmith
Sep 9, 2016 10:02 PM
reedjs
Sep 4, 2016 10:13 AM
S-TYPE06
Sep 3, 2016 08:10 AM
Jaguar Forums Editor
Aug 29, 2016 05:16 PM
ppolicar
US Lower Atlantic
Aug 26, 2016 09:42 AM
