M90 Supercharger Gaskets
Old Dec 3, 2022 | 03:08 PM
SC Chinchilla's Avatar
Default M90 Supercharger Gaskets
Does anybody know a good source of the M90 supercharger gaskets? I couldn't find any online, I've been starting to reverse engineer my own.
There's a thin sheet of coated steel between the supercharger, shaped like:
I'm thinking of getting this lasercut out of copper or something.
There's also the rectangular sort of "O-ring" between the supercharger and the outlet elbow, which I can't find either. I'm not sure yet how I would remake one of those.
Old Dec 3, 2022 | 03:34 PM
Parker 7's Avatar
Aluminum wound be able to crush better for a seal , just my take
There is the possibility of the M90 having more of a MAF for the ECU data maps to optimally calculate the injector pulse width
Your injectors are specific to your supercharged version identified by a color band in the following TSB
There is a O - ring vendor that has them all to choose from
Editing
Couldn't find TSB but I think yours has the red band
Old Dec 3, 2022 | 03:58 PM
I never thought of aluminum as softer than copper but apparently its true. It's also significantly cheaper which is a bonus! I have a few choices with the lasercutter, 5052 is softest.
I was able to get all the simple O rings from theoringstore.com. Or at least my first attempt at sizing them right. The other supercharger gasket is what's on the elbow here: https://www.ebay.com/itm/292156992334. It was sort of a squishy O-ring material.
Old Dec 3, 2022 | 04:07 PM
Parker 7's Avatar
Your caustic blowby gasses would make aluminum a bad choice
Old Dec 3, 2022 | 04:15 PM
Parker 7's Avatar
XJR Fuel Injectors - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 3, 2022 | 08:14 PM
Checked em tonight, they all have the red band.
JX350
44
Jul 3, 2020 03:28 PM
rjs5689
Jun 17, 2014 02:46 PM
jimborino
May 20, 2014 08:12 PM
daboss085
Dec 15, 2013 07:43 PM
WaterDragon
Dec 7, 2012 09:24 PM
